Laguna 2 2007 cabasse: no audio and the cd changer is dead with ignition on
Radio, elektrische ruiten & stoelverstelling, centrale vergrendeling, etc.
manel
repeating visitor
repeating visitor
Posts in topic: 6
Bericht door manel »
hello. I'm writing from portugal because I also have a problem with a Renault Laguna 2 2007 cabasse problem. I have no audio and the cd changer is dead with ignition on. with ignition of I can eject and load cd's but still no sound. does anyone know what is the problem usually?
RichTrip
Posts in topic: 7
Re: Laguna 2 2007 cabasse: no audio and the cd changer is dead with ignition on
Bericht door RichTrip »
Did you check all fuses? One for the radio/navigation in the usual fuse-compartment and one 20A fuse behind/under the ashtray.
manel
repeating visitor
repeating visitor
Posts in topic: 6
yes. they are OK
a video showing the problem:
manel
repeating visitor
repeating visitor
Posts in topic: 6
no one can help me?
RichTrip
Posts in topic: 7
I have a lot of experience with these Cabasse systems, also with repairs. But after reading your story and watching the movie, I still have no glue what is really the problem.
So please try to describe as clear as possible when the system is working and when not. Common problem is a faulty amplifier. No sound at all with some little sound when playing CD's.
manel
repeating visitor
repeating visitor
Posts in topic: 6
Ok...
Sound: when switching the ignition on I get static no Mather the frequency. Then, with variable timing, I get a POP and the sound goes completely off. The amplifier was changed and it's the same. Faulty replacement part?
Radio usage:
Ignition ON: can use without any problem the satellite control, near the stearing. Can't select cd's. CD changer Dead. Even the power button doesn't work neither lights.
Ignition off: can start the radio with power button on the cd changer. Can eject cds and load the last ejected cd.
Still no sound neither lights.
RichTrip
Posts in topic: 7
The popping sound for sure is caused by the amplifier. The strange part is that both amplifiers have exactly the same behavior.
Normally the popping sound does not cause the dead changer when the ignition is on. But the changer is connected to the amplifier, so, if there is a problem with the amplifier, it might be possible that your fault description is caused by that amplifier.
Faulty amplifiers are not extremely rare, so the chance that a replacement amplifier is also faulty, is possible.
manel
repeating visitor
repeating visitor
Posts in topic: 6
ok. I'll try to change the amplifier and try to check for dry solders, especially those two power regulators
RichTrip
Posts in topic: 7
Repair of these amplifiers is not that easy without proper experience. You easily destroy more than you can solve!
manel
repeating visitor
repeating visitor
Posts in topic: 6
I'll have it serviced by an electronic repair shop... any thing that I should say to them to be careful?
RichTrip
Posts in topic: 7
Most repair shops do a trick, without really fixing the several issues which can occur with these amplifiers. After several years of repair experience, together with a full test network for this system, I can assure you that an amplifier is really OK after I have checked it!
stannie1971
repeating visitor
repeating visitor
Bericht door stannie1971 »
Ik heb hetzelfde probleem Rich ,zou jij kunnen helpen?Ben anders bang dat dit een duur geintje wordt. Heb begrepen dat jij al enige jaartjes ermee bezig bent.
RichTrip
Posts in topic: 7
[mention]stannie1971[/mention]: dat klopt, al iets van 8 jaar of zo ;) Wat zijn exact de klachten dan?
Peter1970
2-hit-miracle
2-hit-miracle
Bericht door Peter1970 »
RichTrip schreef: 09 nov 2020 09:10 @stannie1971: dat klopt, al iets van 8 jaar of zo ;) Wat zijn exact de klachten dan?
Ik heb nu net een Laguna gekocht met zelfde probleem repareer jij deze dingen nog? Zo ja dan wil ik graag even contacten met je. Als dat mogelijk is.
RichTrip
Posts in topic: 7
Ik repareer deze systemen nog steeds. Dus je kan mij contacteren.
Peter1970
2-hit-miracle
2-hit-miracle
Hoe kan ik je contacteren via mail of whatsapp?
  • Audio Megane I
    door nikk » 25 jan 2025 18:30 » in Elektrische en elektronische systemen
    Reacties: 8
    Weergaves: 1348
    31 jan 2025 08:03
  • Problemen met audio en mp3
    door Jan van Egmond » 27 jan 2025 14:19 » in Captur E-TECH
    Weergaves: 522
    27 jan 2025 14:19
  • R-Link2 audio werkt niet via telefoon
    door ramonovietsj » 11 feb 2025 08:02 » in R-Link 2
    Weergaves: 885
    24 jul 2025 21:49
  • Navi/Audio upgrade CNC (Megane 3 2009)
    door OriginX » 16 feb 2025 15:35 » in Renault Carminat Navigatie
    Weergaves: 612
    Laatste bericht door OriginX
    16 feb 2025 15:35
  • Audio R5
    door maarten916 » 19 mar 2025 20:29 » in Renault 5 Z.E.
    Weergaves: 923
    Laatste bericht door CakeyEV
    21 mar 2025 14:28
  • Arkamys audio
    door Vertrokken - 48051 » 28 apr 2025 11:48 » in Austral
    Weergaves: 2734
    12 mei 2025 20:07
  • Renault Clio Bose audio systeem werkt niet altijd goed
    door PeterSm » 24 sep 2025 12:10 » in Algemeen Clio
    Weergaves: 516
    24 sep 2025 13:53
