Problemen met mijn automaat
titawae1968
Laatste bezoek: 27 mei 2019 20:22
Bericht door titawae1968 »
Sinds kort heb ik problemen met mijn automatische transmissie van mijn Grand Espace. 3.5 v6..uit 2003 als ik de ecu uitlees krijg ik foutcode P0705 kan iemand mij uitleggen wat dit precies is ?
Gr JosiasAfbeelding
Verstuurd vanaf mijn KIW-L21 met Tapatalk
nikk
Laatste bezoek: 05 feb 2025 06:55
Re: Problemen met mijn automaat
Bericht door nikk »
Ik weet het ook niet maar even googelen geeft oa dit:
"The P0705 diagnostic trouble code (DTC) refers to a switch either external or internal on the transmission whose function is to signal the Powertrain Control Module (PCM) or the Transmission Control Module (TCM) as to the gear shift position -- P, R,N and D positions (park, reverse, neutral, and drive). The backup lights may also function through the Transmission Range Sensor (TRS) if it is an external component. The code is telling you that the computer has recognized a failure in the TRS sensor. The sensor is either sending an erroneous or no signal at all to the computer identifying the gear position. The computer receives signals from the vehicle speed sensor as well as the TRS. When the vehicle is moving and there are contradictory signals being received by the computer, such as the TRS signal indicates that the vehicle is in park, however the speed sensor indicates that it is moving, the code P0705 is set"
Wellicht de sensor naar zijn grootje
Read more at: https://www.obd-codes.com/p0705
Copyright OBD-Codes.com
Megan Berline automaat 1.6 16v '00
titawae1968
nikk schreef:
Thnks
